Spark Plug Torque specifications.
Does anyone know what the torque specifications are on spark plugs for the JK?
Thanks in advance.
I'm thinking of changing th OE's to NGK iridiums. Product Number LZTR5AIX13
Thanks in advance.
From the service manual... The chart is hard to read here... But it's 13 ft/lbs. Coat the threads with anti-seize.
Code:
TORQUE DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sensor Mounting Bolt — 3.8L V-6 Gas 14.1 - 125 Camshaft Sensor Mounting Bolt — 2.8L Diesel 11 8 97 Ignition coil bolts — 3.8L V-6 Gas 11.8 - 105 Spark Plugs — 3.8L V-6 Gas 17.5 13 - Glow Plugs — 2.8L Diesel 14 10 124 Knock Sensor — 3.8L V-6 Gas 10 7 -
Code:
What does the 17.5 number mean above the 13? 13? That doesn't sound right? Are the spark plugs 12mm?
Thanks in advance for the info.
