springs
Old Jul 29, 2013 | 01:38 PM
catahoula's Avatar
Originally Posted by JMcD
I knew everyone would help me out! This forum is great!
No problem. Just like mentitled before I would get leveling kit instead of spacer. You will get links as well. I went from 14/55's before. Very happy with my set up. I don't know size of tires you want but just leveling boasts 33-34" tires. You will need spacers with stock wheels as well. I will go up to 35's down the road. I do have a thread I started "2 dr's with Rubi 18/59 springs, shocks,and spacers and 32's"
Sent while sitting in my Jeep using JK-Forum
Old Aug 2, 2013 | 05:20 PM
RND's Avatar
RND
ACTUALLY, we are NOW running a set of 285/75s (33.8x11.2) on stock moabs (17x7.5) WITHOUT wheel spacers and ZERO issues.
Old Aug 2, 2013 | 05:33 PM
RND's Avatar
RND
I used to be a proponent of wheel spacers until I saw that some of the studs were fricking toast after 26 months. AEV has it right keeping thee offset and back spacing they do on their wheels for folks running 12.5-13.5 inch wide wheels. Stands to reason that an 11.2-11.5 wheel would work wonderfully on stock OS and BS.
Old Aug 2, 2013 | 05:45 PM
karls's Avatar
You say the studs were toast....can you elaborate on this? Were they loose, corroded, stripped, cracked, stretched?? I'm just looking at what to look out for.
Sent from my Droid4 and Jkfreaks.com
Old Aug 2, 2013 | 05:49 PM
RND's Avatar
RND
Stripped and cracked. Had pieces of them seared into the lug nuts.
Old Aug 2, 2013 | 06:01 PM
catahoula's Avatar
I think a lot of folks use impacts. I've had mine on for several thousand miles and no problem. I torque and re-torgue by hand per spec.
Old Aug 2, 2013 | 06:04 PM
catahoula's Avatar
I believe that is recommended per Teraflex. It might also depend on width of tire and if you wheel or just mall crawl.
Old Aug 2, 2013 | 06:07 PM
JK Inspired's Avatar
Ditto: re-torqued by hand every Dino oil change.
Old Aug 2, 2013 | 06:10 PM
I will not have any issues wheeling, GUARANTEED (Cajun accent).
Old Aug 2, 2013 | 06:12 PM
Enough about wheels and wheel spacers. Back to the OP
