Squeak from both rear wheels
Old May 2, 2010 | 06:18 PM
kidkoala's Avatar
Same problem over here. Driving me crazy - at first it was mainly when I applied the brakes. Now it's pretty constant.
Old May 3, 2010 | 09:50 AM
JK-Tex's Avatar
Mine squeaks over ANY little bump or road imperfection. It has gotten progressively louder -- to the point where I'm almost embarrassed by how ghetto it makes my Jeep sound. I'm installing a lift this weekend and plan to investigate further. Glad to know I'm not the only one who has this problem.
Old May 3, 2010 | 10:39 AM
07JKX's Avatar
same here... lol... those shield has caused more harm than good for me. Shit is always getting stuck between it and the rotor. Anyone see any long term issues with removing them all together? Are they bolted on, molded, or welded?
Old May 3, 2010 | 11:46 AM
Dronac's Avatar
Yep, mine does it as well. It's the rear left wheel and it squeaks when the breaks are applied, yet the pads look brand new.
Old May 3, 2010 | 07:22 PM
Ormrod's Avatar
Mine is still squeaking and I haven't had a chance to take apart the wheels, but I noticed sometimes when I put the parking brake on when I'm on a hill it squeaks.... Are the e-brake drum/pads behind that same dust shield?
Old May 4, 2010 | 04:50 AM
07JKX's Avatar
the e-brake is a drum style setup that sits behind/inside your rear rotor. so yes its behind the same dust shield but there is no way any of those companent would be touching it. The shoes could be worn or dirty and causing a squeak when your e-brake is one
Old May 4, 2010 | 05:16 AM
JK-Tex's Avatar
I'm still thinking the dust shield (or something very nearby) is the likely culprit. I will investigate in some detail this weekend.
Old May 5, 2010 | 01:56 AM
montrealer's Avatar
Have you checked the wheel bearings ? does the squeeking sound increase when you turn in one specific direction ? also, if it squeeks over bumps, table bushings could be the culprit.
Old May 11, 2010 | 08:17 AM
JK-Tex's Avatar
Well, I installed my lift (see sig) this weekend and the squeak is gone. I'm not sure what this means.
(a) The reprieve is temporary and the squeak will return.
(b) I replaced the part that was doing the squeaking.
(c) Whatever was squeaking is now at a different angle as a result of the lift, which has eliminated the interference that was causing the squeak.
I am happy it's gone, but dread its seemingly inevitable return.
