Squeaky Clutch!
Old Nov 2, 2011 | 07:08 AM
JeepPilot10's Avatar
Good to know. I've lived with it this long and didn't really pay attention to it any more.
Old Dec 20, 2011 | 09:12 AM
HighRoad's Avatar
Should've read this thread first, now my cabin reeks of WD-40 and ignorance. Same issue here, '07 with 50k and the squeak is there on in and out. Instead of listening, I tried to feel where the squeak came from. From what I can tell, it feels like the pivot right before it goes into the boot before the firewall. I'm going to try some industrial grease when I get home, see how that works.
Old Dec 20, 2011 | 09:45 AM
JackDANJK22's Avatar
Originally Posted by JeepPilot10
My squeak seems to be coming at the hinge inside the cabin just at the fire wall. I can't tell if it's the little rubber boot covering the hinge or the hinge itself. Squeaks going in and out.
I too have the squeak ! 2012 , 1000 miles
On it , I'm on the same theory as you my friend ! Either the hinge or the boot ...
SOLUTION = blast some jeep tunes gotta use that infinity system I ordered some how ..... But I think it's just the harmless hinge !
Old Dec 20, 2011 | 05:55 PM
crankinaway's Avatar
What he said. My 2012 squeaks too. Some days more than others and who knows why?
Old Dec 21, 2011 | 05:13 AM
drumnatural's Avatar
Nice to see the throw bearings still suck. Only real solution is aftermarket.
Old Dec 21, 2011 | 05:49 AM
JKred's Avatar
Is the squeak internal or external. Mine has two squeaks/creaks, one from the spring on the clutch pedal itself, and one from the slave cylinder/ball and socket interface.
I have cleaned and regressed the cup on the clutch yoke twice now, and the creaking goes away until I wheel again, or at least see mud. It's probably just dirt in the grease, there isn't that great of a seal between the slave cylinder and the bell housing.
Old Dec 21, 2011 | 05:52 AM
HighRoad's Avatar
When I hopped into the jeep after work yesterday after I had sprayed the pivot over lunch the squeak was gone. I was pretty stoked, until about 10 mins into my ride home I could feel it again when shifting. Turned down the tunes, sure enough we were back to squeaking. Fail .
Old Dec 21, 2011 | 05:55 AM
JKred's Avatar
Try white lithium grease or silicone grease, I've found those to work the best. You have to spray it inside the spring.
Old Dec 21, 2011 | 05:06 PM
My squeak is definetly in the cab. For now I will live with it since my music normally drowns it out, I'll chalk it up to the Jeep needing more break in time.
