Steering wheel upside down after accident
I was making a left turn onto a 5 way street in Chicago and an old lady in oncoming traffic hit my drivers side tire. No one was injured and I didn't notice any damage to my JK. The lady managed to blow out her drivers side tire and got some tire marks on her front bumper.
Today I noticed in order to drive straight my steering wheel is completely upside down. Both front tires seem to be pointing outwards as opposed to being dead straight. I checked for bent components (tie rod, drag link, track bar) but didn't notice anything out of the ordinary.
My traction control light is on and the jeep drifts to the right when I let go of the steering wheel. The steering still tracks after making turns but it stays upside down at all times.
I am in the middle of the insurance dispute and just want to figure out what is wrong.
Maybe an alignment issue? Any ideas?:crazy:
I would check the steering box and drag link for damage. Also pull the wheels off and check the hubs and inner C's.I think more than a alignment prob.
I'd be careful if you try and adjust to straighten steering wheel. Damage to clock spring...
In the meantime you can straighten out your steering and get the light off by adjusting the turnbuckle on the drag link. With the wheels straight, just loosen the two bolts and rotate the turnbuckle until the steering wheel is straight, then tighten them back up. But it sure looks like something is bent. Maybe bent a ball joint, spindle, or inner c? I would pull the wheel and inspect everything so it doesn't come apart on you while driving.
Any front tire impact can cause a host of parts being bent, broken, or out of spec.
Like others have said:
1. Steering Box
2. Drag Link bent, Drag Link Ends damaged
(Drag Link length can be adjusted to recenter your steering wheel).
3. Tie Rod bent, Tie Rod Ends damaged
(Tie Rod length can be adjusted to set Toe, for stock tire approx. 1/8" less width front of tire than back of tire)
4. Front Knuckle
5. Front Ball Joints
The adjustments are pretty simple to do, you only need a 15mm socket/wrench, liquid wrench (if rusty), a vice grip/plummers wrench/channel lock pliers (if rusty).
Google "DIY Jeep JK Front End Alignment"
I would take pictures (current condition), reset toe (by shortening tie rod length), recenter steering wheel (by twisting drag link adjustment sleeve).
Then I would bring it to a reputable auto repair shop to have it looked at.
So who had the right of way?
1. Steering Box
4. Front Knuckle
Hi, have you fixed this? I just want to get more info, if you don't mind. Well, I'm asking after those years, cause I searched for some related to fixing threads.
