Still pinging! Why?
if someone could post a pic of this knock sensor that would be great, I've had pinging for some time now tried different brands, different octanes, put fuel injector cleaner and fuel system treatment thru 2 tanks on the dealers advice and still have the pinging, dealer says its normal, i want to try this sensor if its only $18...is the exact term "knock sensor" or will i get the deer in the headlights look when i ask at the parts counter.
called one of the guys at the service dept, and left a message on his direct line..told him i had them check out a noise not long ago that i heard, like a rattle can sound coming from the engine..they thought it was a heatshield..told him that im sure its pinging and that im concerned..im due for service next week and i told him i want it looked ASAP. its only 2k-3k RPM's, i dont take it on the highway much, and i rarely go above 3k rpms at all..find it kind of sluggish on the highway..maybe it does have carbon build up..i just want to make sure im covered at the dealer. checked the spark plug i could get to myself and it was perfect..was thinking that would show carbon. jeep is pissing me off lately.
Local dealer told me he didn't have the sensor in stock but that there were like 1,200 on order somewhere, I gather from some regional supplier... makes me wonder if this is a known problem and they're gearing up to replace sensors all over the place. Just a theory, don't take it as truth. I don't want to start rumors.
Anyway, it was pissing me off too, and that's when I decided to take care of it myself. I checked the air cleaner element - no problems. I didn't pull plugs because 1) some are hard to get to, and 2) I was about to try the sensor replacement which I thought was more likely to solve the problem.
Have you tried a different brand of gas? My jeep seems to be happy with Shell 87. I was using Mobil 93 before, then Mobil 87, but switched to Shell 87 at nearly the same time I replaced the sensor. No more pings, and not exactly sure what was responsible for it. My money's on the sensor though.
Last edited by mostlystock; Aug 6, 2010 at 03:33 PM. Reason: Corrected my gear ratio - thought I had 3.73 but really have 3.21
i was using irving 87, switched to mobil 87 and still have the ping..i bet its the sensor after hearing that..i can't wait to hear what my dealer says about it..it just sucks to take off at a good clip from a light or a stop, and hear your engine sound like a rattle can. for 30k you'd expect better...makes me want a hemi!!!!!!!!!
talked to the dealer today..they said its possible its just carbon buildup, and recommended i use a fuel system cleaner..highway was too busy to get it really high in the RPM's..but i added a full container of STP fuel system cleaner to a nearly full tank of gas..so by the end of the tank ill know if it helped or not. due for an oil change next week so we'll see what happens.
EDIT: i know people have been told to do this by the dealer before, but i did it just to satisfy them, and if i go in next week with a ping/knock, they'll know i tried
Good luck, hope it works.
well i know the techron needs an empty tank..the STP says to use on a tank thats at least half full so im thinking of trying techron on empty if this doesnt work..last night i had a really long on ramp in front of me with no traffic, and i got it up to 4,500K rpm..even after doing that, i couldnt hear the pinging on the way home..i doubt its the STP stuff already but who knows..i did a lot of driving last night.
