Stock fog lights no power
I just got my 13 JK, I noticed the fog lights don't work. I tested for power and got nothing. There isn't a fuse for the headlights and fogs is there? Is this a common thing? Any ideas?
Pretty sure the fog lamps run through the TIPM so you likely won't find a relay or fuse for them. I don't know if the fog lamps run on the same pulse type system as the headlamps. If they do, you won't be able to measure a voltage with your multimeter.
You're sure the bulbs are good?
