Stock JK wobble
Old Feb 22, 2012 | 12:20 AM
TINMAN080's Avatar
Default Mine has started
A woman changed lanes on me at 55 mph, I put it into a panic stop. Ever since I have had the death wobble. I mean a violent 4'' back and forth shimmy, seen during an episode by the shadow of the tires on a guard rail. Dambdest thing I ever saw. If you have this happen, pull it into 4wd hi immediately, drive force seems to stabilise the episodes. I've checked alignment, balanced the tires, replaced the stabiliser. I guess tires will be next....
Old Feb 23, 2012 | 09:41 AM
turtoni's Avatar
Did you tighten up the track bar and/or replace the nuts and bolts with slightly bigger? This is supposed to be behind 99% of the wobble problem? I'm doing that hopefully next week sometime. One side is going to be a sob though.
Old Feb 23, 2012 | 02:47 PM
DelVecc's Avatar
Just got back from the field. Checked my track bar. There is slight play when i turn the wheel. On both ends. Bushings look intact. Just to clarify there should be no movement in the track bar what so ever.
I guess the first thing i will go is tomorrow change the bolt size and see if that quells the movement.
Old Feb 23, 2012 | 04:34 PM
JKcondrey's Avatar
Track bar, track bar, track bar.
Old Feb 23, 2012 | 04:57 PM
DelVecc's Avatar
When i replace the bolts do i jack the jeep up replace the bolts, drop the jeep down then torque the bolts?
Is there a chance i can knock it outa alignment?
Old Feb 23, 2012 | 08:48 PM
TINMAN080's Avatar
Track bar has been checked repeatedly. I've had this on my lift several times and there is NO movement of the track bar, the bushings haven't moved and the bolts are so tight they're bleeding.
Old Feb 23, 2012 | 09:59 PM
turtoni's Avatar
Figger'd you'd have done that! Now come and do mine!
Old Feb 23, 2012 | 10:01 PM
turtoni's Avatar
I think you have the Jeep level and crawl around underneath swapping out the bolts and nuts on both sides at the same time. Jacking one side up and then the other would probably make things much more difficult if not impossible.
Old Feb 23, 2012 | 10:22 PM
OOC-07Rubi's Avatar
I did mine...changing to 9/16 bolts with all wheels on the ground. Everything lined up fine. If you raise it, you have to lower before you torque down bolts.
Old Feb 23, 2012 | 10:32 PM
Xman4602's Avatar
Originally Posted by 210GoldenEagle
Ive had something that felt like death wobble but I'm pretty sure it was just snow in my tires throwing out the balance but it scared me enough to try to fix the problem before it happened for real.
I got the kit from northridge today in the mail and planning on installing it next week. I've heard that this is a fix for death wobble but we will see
Is that the grade 8 bolt kit? I think I'm ordering that tomorrow with my bumpers. How much did you shell out for that?
