Stock Wrangler X
yeah, the traction control really helps... but it's still not locked up.
i think the bottom line is that it's a wrangler, it's better than just about anything other than a better equipped wrangler.
Stock tires and lift in an X (did have TF QDs for some of this, and I do have LSD):
The Rock Garden at Disney, OK (running with the Rubi's, JackMacOKC guiding):
Following Armycop's Rubi down a steep hill at Disney, OK:
Okay, Armycop and Torn took a much tougher route in their lifted Rubi's--but this is where everyone else went at Disney, OK!
Stock tires at muddy Stanley Draper Lake--No problem!
Okay, this is where we had to turn back at Stanley Draper Lake. But notice: JackMacOKC's Rubi didn't get much further!
Hi folks,
I have a totally stock 2D JK, 6spd. In 4L it will go places that I can't walk. I met my own "envelope" before the JK met hers! I won't go "rock crawling" as that is NOT what I bought her for. I do enjoy trail running with MINOR to MODERATE mud holes but none of that extreme stuff the younger folks do.
My advise to you is to go out with freinds that you trust to not get you in over your head and work your way up slowly until you know where you want to call it your limit. Don't rush it...hopefully you'll own your JEEP for a long time and can gain experiences slowly! Take care... Mike
before I upgraded the tires on my JK, I took it out with the stock 225 tires, and was impressed on how well it actually climbed some steep rocks, and plowed through mud without slipping getting stuck, or any other negative results. cant waitt o go try it out with the new tires, and when I get the electronic swaybar disco installed (yes im that lazy ).
I agree with most here in saying the x can do a lot of things you can do with the rubi. But in the enviroment the rubi was geared towards, the x will tap out first. The brake assisted traction control has it's limits & so does LSD. If you hit the rocky, off camber three & two wheeling type terrain those lockers really start to shine.
On the other hand for me I start weighing the potential for damage against the number of years I expect to own this thing & I end up bypassing some things I probably could have gotten through. I was amazed at how well the x unlimited dragged itself across high centers on big levels in VA.
The TJ Rubicon came with 245/75R16's which are more like 31's (technically more like 30.5")....I think that's the size that comes standard on JK's now, or maybe even the 255/75R16.
Hi folks,
Oh, he punched a hole in his front diff and ripped off his track bar mount trying to take a pretty rough rock patch, that no one else was willing to take.
