stupid question
Old Jul 28, 2009 | 11:46 AM
flounder's Avatar
Question stupid question
When I wash off the engine is there anything I need to cover and not get wet. Or can I just spray it off and not worry about it.
Old Jul 28, 2009 | 11:51 AM
sciguy6's Avatar
Considering how messed up it gets under there, I would say most things are pretty water resistant. I would not spray any wires or electrical stuff directly. I Simple Greened the dirty stuff and wiped what I could and then with a real weak stream, I rinsed things down. Be careful. I almost hosed into the air inlet (bad).
porters's Avatar
You would not want to use a pressure washer. Just some simple green and a spray hose should do the trick. No need to worry about getting anything wet.
Old Jul 28, 2009 | 10:19 PM
flounder's Avatar
Cool guys thanks for the assist.
Old Aug 1, 2009 | 01:00 PM
CajunJack's Avatar
I also avoid spraying around the air cleaner intake. A little water doesn't hurt, but spraying into it will leave moisture in the botom of the box.
Old Aug 1, 2009 | 03:49 PM
mkjeep's Avatar
Stick a rag in the airbox inlet, and just don't go crazy on water aiming directly at your fuse box and altenator, you'll be fine.
Old Aug 1, 2009 | 05:58 PM
09SUNBURSTJK's Avatar
There's something under there that doesn't like getting wet. Mine stalled after running through about 8 inches of water and would not restart for about 30 minutes. It would turn over and sputter a bit but stall. We did run through the water fast enough for the top of the motor to get wet but there was no water in the air filter box. Not sure what got wet though.
Old Aug 1, 2009 | 06:07 PM
09rubicon's Avatar
Just remember to let the engine cool until its cool to the touch before you spray. Dont want to prematurly cause any manifold cracking, it will come on its own with time!
Old Aug 1, 2009 | 06:56 PM
4x4jkx's Avatar
Plug the airbox and spray away with the pressure washer. That's what I did. Just keep a decent distance. You want to knock the dirt off the engine... not the wiring.
