surface rust! what to do? PICS
Old Oct 23, 2008 | 05:28 PM
  #21
4x4jkx's Avatar
Originally Posted by RedneckJeep
THIS is what "rust all over the frame" looks like.
Is that light shining through the frame?
Old Oct 23, 2008 | 06:20 PM
  #22
Parrothead's Avatar
How long did that take you? Can I do that in a weekend?
Old Oct 23, 2008 | 07:14 PM
  #23
Widewing's Avatar
One problem with rust is that more often than not, wire brushing and sanding is insufficient. Just spraying RustOleum over it will only result in the paint blistering as it rusts under the dried finish.
To really eliminate future rust, you should spray or brush on a quality rust conversion product. The Permatex rust treatment works well and there are several other manufacturers of similar products. Apply several coats, allowing each to dry first. You can prime the surface, but it isn't necessary. Then, you can apply RustOleum or any other quality paint. In all probability, the area you just treated and repainted will be more durable than the original finish.
Just remember, it's difficult to remove all oxidation using a wire brush or even by sanding. Using a quality rust conversion product will guaranty that the oxidation is neutralized and your repainted surface will not blister months later.
My regards,
Widewing
Old Oct 26, 2008 | 06:32 PM
  #24
KMacJKPA's Avatar
Try POR 15 (Paint Over Rust), you can get it at Quadratec.
