Suspension lift
Suspension lift
Thinking of doing a 3-4 inch left really don't know witch one yet but also didnt know if after I do the lift do I have to do anything extra to the jeep
Former Vendor
#1 Question: What are your future plans with the Jeep?
-Tire size desired
-Do you wheel it? (Terrain Light/Moderate/Extreme)
Your ideal lift height is 2.5" - Not much of a need to swap to adjustable control arms, track bars, etc... 2.5" allows you to easily fit 35" tires.
Good luck
-Tire size desired
Good luck
With a 4" lift you'll have plenty of room for 35's when you go wheelin. It'll still handle well on the street, depending on whose lift you use. If you ever want to go bigger, you'll have room as well.
I run the RC 3.25" on my unlimited and have had it for almost 3 years and 43K miles.
It has been great for a daily driver. 35's in the summer and the stock 31's in the winter.
I did not have to add anything more than was in the kit and it has been fine but no wheeling.
If you have the 2 door I believe from posting you may need to be a bit more cautious as the shorter wheelbase may have different results.
My 2 cents.
Mandor6863
My 2 cents.
Mandor6863
