Tail Light Flip Issue.
Edit: other posts came in before I finished mine
my first real mod was to get a rigid dually d2 in diffused pattern and I mounted it on top of the drivers side brake light pod. It is wired directly into the backup power circuit.
works great! Plus now with 37's my rear window is nearly blocked, so the super bright backup light hopefully gives an extra level of awareness to folks that I'm backing up!
I am contemplating adding a second d2 to the passengers side...
matthew
I tried leaving the shims on the correct side and switching the housings but the shim did not line up properly. I did some trimming to make it fit, only to find out the shim and the tab on the housing will not line up properly with the body.
That would probably get the wrong kind of attention on the highway...
Although might be good for tailgaters.
