thumping noise in door pillar
Your door striker is out of adjustment. For a test, wrap some electrical tape around the striker 4 or 5 times and try that. I can almost guarantee this is your culprit, it has been discussed much in the past.
Jim
Jim
I also have a thump or rattle in the drivers side pillar. I pulled the plastic molding off and where it over laps there is a piece or pin that goes into a hole on the metal pillar. It does not seem to be attached there, it just seems to sit in the hole. If you depress the lower piece you will here the rattle. I am going to rap duct or electrical tap around the plastic pin to see if it stops.
If that doesn't work I will check the door. I have put pressure on the door when going over bumps to no avail. So I hope the cheap plastic is the problem.
https://www.jk-forum.com/forums/stock-jk-tech-12/annoying-noise-problem-4110/
it took a lot of trial and error but for most the noise has gone by moving the striker.
