Annoying Noise Problem!!!!!
SEE POST #46 for Solution
OK Guys
Going over small bumps or just normal driving I hear as sqeaky noise coming from the seat belt adjustment area. Its right at my left ear. I went as far as putting the seat all the way down and slid it all the way back trying to find the noise. Its driving me nuts. Also the weird thing is it goes away when someone is sitting in the back left seat.
ANYONE????????? I know its not just me?!?!?!?!?!?
Mike
OK Guys
Mike
I have it too and its driving me crazy I cant pinpoint what or where it is, all I can tell is that it sounds likes something loose, plastic, and around the seat belt adjustment slide area. I have tried to remove the plastic cover around the roll bar on the drivers side but cant see what could be causing it, if it continues I will rip out the plastic cover.
yeah i had been having that same noise around the seat belt adjustment area on the passenger side. i moved the slide adjustment for the seat belt all the way to the top position and it seems to have stopped the noise. we'll see if it comes back, but so far so good.
I tried that and it didn't work, what I have noticed is that its worse when its cold and less noticable when warm/hot, so I figure something is expanding/contracting and when cold its loose and more prone to squeeking. I tried the tape on the door catch idea and its not that area that makes the noise.
I thought the noise was coming from the door seal around the door so I treated it with weather stripping solution, but that wasn't it. Its weird and I HATE IT. Geez.
I had my wife drive while I was in the back seat and I coulnd't hear it.
Then I moved over to the pass side and it came back but couldt be there to listen. Arhhh!!
How bout take the whole Jeep apart and put it back together my way. That may work
I have got the same squeaking chirp noise as well..sounds like coming from the passenger side in the rear...can you adjust the seatbelts in rear??? I'm thinking thats what it is, but i have to keep my eyes on the road and its hard to pinpoint the damn noise
