Tightening Bolts After Off-Roading
Hi all, just went off roading again yesterday and had a blast! Nothing sounds, nor feels loose under the Jeep, but I have read/been told I am supposed to tighten up bolts after each time I go off-roading. Does anyone know which bolts I should be checking for tightness? This is the second time I took the Jeep off road (bought it Feb 19, 2012). Thanks!
I do if I notice anything feeling a little "loose" in the front end or any shimmy. Most often you will find trac-bars loose but some people find their control arms and also their sway bar links work loose. Anything that flexes or rotates can work itself loose while off roading
Battery restraints. If they go loose and fall out your battery gets smashed to pieces and it's game over. And you get acid all through your engine bay. It really burns when you rub up against it while workin on your rig.
Also sometimes wheel nuts come loose.
Its never a bad idea to get underneath your rig after wheeling to check everything out before you head back onto the road.
This past weekend i found one of my sway bar links had loosened on the axle side and was making abit of noise when I was offroad, tightened it back up and its all good now.
Just noticed a slight banging sound in the rear if my rubi. Took 10 mins to find. Wires came loose in the tail gate fixed with a zip tie in 2 mins. So check wiring is still secure after wheeling in obvious areas under bonnet, and body after wheelling.
