ugg before i bring my jeep into the stealership...
i figured i would post my issue here....i have a 2012 jku and today i noticed the left pass. door wouldnt close....i didnt have this issue yesterday and today i do....i didnt leave the house.....i have never remvoed the pass. doors. I have to really slam the door to get it to latch if i dont slam it it wont close and when i go to open it i really have to push the door handle it and its even then you can tell the door is just not right....i cant tell if its not lined up because it was 9:00 when i noticed the open door warning on the dash any ideas?
I had an issue similar where the softtop wasn't on right and it was interfering with my rear pass door. Double check the soft top. If not let the warranty fix it.
If the door closed properly before you removed the windows, then you did not put them back on correctly. If you are new to the soft top, it takes a few times to get comfortable with it.
Good luck.
Good luck.
If it is the back door, make sure that the window is all the way into the surround. If it is the front door I don't really see a way that the soft top could interfere with the door. Esp if you did not take the surrounds off.
