tire rotation
Old May 31, 2012 | 11:03 AM
countrybassist's Avatar
Originally Posted by ronjenx
This is the 5 tire rotation I use every 5 to 6 thousand miles.
All the tires are within 1/32" of each other, no cupping, no uneven wear.
At 48,000 miles, they still have 10/32" tread on them.
One thing I like about the 5 tire rotation is it can be done one tire at a time.
This is what I do too.
Old May 31, 2012 | 11:45 AM
KDBinAZ's Avatar
asked my dealer what there protocol for a 5 tire rotation was and he looked at me with a dumbfounded expression and said "we don't do 5 tire rotations".
I laminated a copy of this 5 tire reward cross and keep it in the jeep when they do the rotation. I do every other as the will do it for free every 6K miles and I rotate every 3K
By rotating all 5 you actually get 20% more tread life so to me it's a no brainier to rotate all 5
Old May 31, 2012 | 12:55 PM
plntman's Avatar
I always do the 5 tire rotation but I put the rear tires on the front but opposite side so LR goes to RF and RR goes to LF spare goes to the rear and one front to spare location. I have always done it this way dont know where I learned it.
Old May 31, 2012 | 01:41 PM
johncantello's Avatar
I rotate all 5 about every 6-8k miles. I have been starting with the spare and then move clockwise starting with the left rear to left front to right front to right rear to spare. Everything seems to be wearing evenly and it only takes about 30 min with a floor jack.
Old Jul 6, 2012 | 07:32 AM
Hydroslyder's Avatar
Quick question, so I've been neglectful and am at 11000 miles and haven't done a rotation...is it too late to rotate in my spare tire?
Old Jul 6, 2012 | 09:00 AM
BornJeep's Avatar
not too late IMHO. I went 10k miles on my rotation once and it didn't seem to matter. I usually rotate every 5k.
Old Jul 6, 2012 | 11:31 AM
Thanks, yea I figure I'll rotate it in this weekend and see how things go, if there's some vibration I'll know why and if I have to swap the spare back out
Old Jul 6, 2012 | 12:25 PM
hypeiv's Avatar
There are two schools of thought...
Most common is you throw the spare into the rotation... in theory if you rotate your tires 4 times before they wear out every tire gets a break for a few thousand miles, thus extends the life of the set for a few thousand miles.
The other school of thought is if you have a blow out, you will have to buy a new tire. The new tire will have full tread, so you can put the brand new spare on the same axle as the new tire and that axle will have the same tread. (but then what do you do the second time you have a flat?)
I subscribe to the first school and think I will rotate my spare in... if I ever have to get a new tire I will likely throw it on the back and not rotate it in untill I buy other new tires. As long as I don't have more than one blow out per set, I should be good to go.
edit: I figured it out:
rotate all 5,
after first flat put new tire on carrier and rotate 4 remaining
after second flat mate the fresh tire with the replaced tire and put a worn tire on the carrier
after thrid flat - ???
Old Jul 8, 2012 | 06:49 AM
skillet's Avatar
I never rotate my tires on any of my cars. I believe tread wear will be less if you don't rotate. My theory is when you install a new set of tires on a car the tires go through an accelerated wear-in period for a short time. This cycle is repeated every time the tires are rotated causing higher wear than if they are never rotated. One negative is two tires might need replaced prior to the other two. I consisting get higher than the rated miles for tires. Been doing this for 20+ years.
Old Jul 8, 2012 | 07:02 AM
Liquid741's Avatar
Originally Posted by arjeeper
Many folks these days don't do 5-tire rotations. The biggest reason is that on many vehicles, the 5th tire/wheel combo is a steely or donut.
On Wranglers, everyone should do 5-tire rotations. If you keep a "fresh" spare, it just means you'll eventually get an aged, old, UV damaged tire that you may not want to use, but which has 100% tread.
The 5-tire rotation maximizes the tread of all 5 and keeps all your tires newer, longer.
The one exception might be if you plan to change your tires soon and sell the originals, in which case the unused, new spare might fetch a bit more money.
Thread...plain and simple.
