Tire Rub Q275-uestion
Old Mar 27, 2012 | 01:12 PM
ISULarry's Avatar
Default Tire Rub Q275-uestion
All,
Did a search but didn't find exactly what I was looking for. Can anyone tell me if a Duratrac 275/70R17 will rub on a JKU with stock rims, no spacers no lift?
Thanks!
Larry
Old Mar 27, 2012 | 01:46 PM
whitejeepjk's Avatar
I had asked this a few days ago, on a stock jeep I was told you should be able to get a 285 70 17 on no problem, there may be some slight rubbing on a full turn but that is it, spacers will further prevent, it is more the width then height
Old Mar 27, 2012 | 01:58 PM
8000ft's Avatar
Yes, they will rub on the sway bar and brake lines. I put on 1.5"Spidertrax to get rid of the rubbing but now they rub on the fender lip at full compression. I trimmed the inside of the lip with a razor knife. It will just have to do till the lift fairy arrives.
Old Mar 27, 2012 | 02:00 PM
airforce26yrs's Avatar
I am running 265X70X18 on stock Sahara rims and have minor rubbing at full lock left on the sway bar. I just do not go full lock.
Old Mar 28, 2012 | 05:27 PM
crg41890's Avatar
I would guess they will rub on the fenders during articulation. My stock 255/75/17s rubbed the fenders under extreme articulation when disconnected before I installed my lift.
You may be fine on the street but as stated above I'd watch the sway bar links and brake lines at full lock.
