Tire Storage
Tire Storage
Im getting new tires and want to keep my stock rubi tires incase I need to take it to the dealer for something important, and specifically for the 5 year lifetime waranty inspection...
Anyone know the best way to store the tires long term? An important fact is that the tires will have to be stored outside due to space limitations. They will be behind my shed in a spot that is shady all year round and will be covered with a tarp
Regardless, make sure the tires/wheels rest on their sides (horizontally). You can even stack them up on top of one another. But don't let them rest vertically, lest they end up getting flat spots.
Bag them in heavy duty plastic bags. Get some dissicant bags (Like the tinybags in electronics) to eat up the moisture (I think they sell them for Corvette storage for the interiors and they are larger) and put it in. I think even like ACE hardware or True Value had some anti moisture stuff and it would be cheaper. I agree that if you can, get them inside somewhere.
Will the tires be on rims? It makes a difference.
http://www.conti-online.com/generato...torage_en.html
There is really no room inside anywhere...and I only plan on ever using them to drive to the dealer and back. I thought about bags, but I figured a tarp would be better so I didnt trap moisture inside
I do have a deck box filled with firewood...maybe if I get rid of that they can go in there...
Since you will only put them on when you go to a dealer for something 'special' I wondered if you have a buddy that's stock. Maybe someone with an X or base Sport that would like to have your take offs.
Maybe you could sell them to him and make him a good enough deal that he'd let you 'borrow' them when you need to go in for that special service appointment.
Just a thought. That would put some cash in your pocket and solve your storage issue and wouldn't create any more of a swap out problem than having to move them off the ground to your Jeep.
That would be a giant pita to coordinate with the other owner.
I know I wouldn't want to remove my tires every time the guy that sold them to me wanted to go to the dealer.
Ideally, I would try to make room in the shed as it would be dry and shady! If you can't then for sure get a pallet to set them on and cover with a tarp. Don't place the tires directly to the ground due to moisture from the soil. Before storage I would wash them up good and add some tire cleaner or 303 protectant to the rubber before storing.
