Towing witha JK Unlimmitted
Does anyone have experience ion towing with a new JK Hnlimmitted Sahara? I am wondering if the stock tranny cooler is enough to keep my automatic tranny happy. It alos looks a little tight for space to add an additonal cooler...
Try doing a search, there are threads on Trans coolers and even a group of pictures in one where a guy installed a cooler with builtin fan. In general yes, by all means get an after cooler.
You will need to provide more info on your Jeep for others to help, like gear ratio, tire sizes, do you already have a trailer pack, year mdl.
I towed a trailer from GA to AZ at high way speeds and had no problems. I have the 6 speed so I don't know if that would make a difference, but I was impressed with the performance.
I have no doubt the Jeep can tow much more than advertised weight but be careful if you decide to go over the MFG weight rating because if you get into an accident you could be in big trouble with your insurance company.
If you are towing less than 3500# you should be in good shape. Make sure your trailer has either hydraulic brakes (surge) or better yet, an electronic over hydraulic set up which will require an in car brake controller.
I have a TJ Sahara which I used to pull (not tow) my 4500# boat out of the water and it did it at low tide on a slippery ramp with ease each and every time. But I would not want to tow that load down the road for safety and other purposes.
My towing experience is very limited with what you can see...BUT i can already feel a problem: the BRAKES...I would upgrade my brakes if i had to tow something heavier! mmmmmmmmmmm brembo brakes ...
