TPMS and Tire Pressure and Warning Light
I have set my tire pressure warning at 30 lbs. with my flashcal. Actual tire pressure is 35lbs in all tires. I installed a new Pioneer radio that connects to the obd port and it also shows all four tires on the ground and the tire pressure to be 35 pounds, but it also shows the tires to be red instead of green. I have tried removing the battery for 10 minutes... No change...
Since I am seeing the correct tire pressure on my radio I am assuming the TPMS system is working. I am beginning to think this is a computer issue. Anyone else experience this?
Thanks,
Russell
Thanks,
Russell
The low tire alert on the dash isn't lit up right? If it is not, it sounds more like a radio thing than a jeep computer thing to me. I could see the radio doing that if the jeep itself was flagging you with the low pressure alert.
