TPS and cold weather
spending some time in Ohio, got wicked cold, -9 overnight, jumped in the JK and the TPS is now on.
I have not checked the pressure yet, but eyeballing them, none looked significantly low.
I live at 8800 ft in CO, and it has gotten pretty cold there, but with zero humidity in CO, the cold is certainly different.
Would the cold here in Ohio have an impact on the my TPS readings?
Thanks.
Thanks.
Cold air will cause lower pressure in your tire. In the morning mine will show around 37psi and after driving and the outside temps climb it can show 41-42psi.
Yup, for every 12* F you'll lose 1 psi. So if you filled your tires to 35psi at 63* you would have been at 29psi this morning.
For those 2012 and up with the display remember you should aim for 35psi "cold", not after you been driving for 20 minutes. It's normal to be in the 37-38psi range for me when warmed up.
You sure can't tell a couple pounds of loss by looking at them ! In the amount of time it took you to post this , you could have easily checked your pressure !By the way , just do what I did and break them all off on rocks and look at the light on the dash board forever !
Each tire seemd to be a ~7lbs low, topped them all off, all good.
Be sure to check the tires again when the weather warms up to normal. You'll probably find them to be inflated past what you'd regularly run them at.
