true or false did the 2007 X come stock with 4:10 gears
#43
https://www.moparownercenter.com/oc/...nersLogin.aspx
and create an account, the account creation process asks for your VIN. After you are logged in there is a factory build sheet available to you under Learn & Use> Equipment. Gear ratio is listed as Rear Axle Ratio on the Standard Equipment tab but if you find an Axle Ration under Optional Equipment then that is the true ratio as it was an upgrade.
They will send you oil change coupons every month or so via email.
**edit ratio not ration
