TTY bolts for a 3.8
main caps you can use arp 151-5406 (ford 2.0L zetec) they fit perfectly in two late model 3.8s that I have worked.
Side main bolts I measured and replaced with four grade 10 flange bolts (because I had them), the torque is very low so grade 8 would work easily but I forget the size and depth.
rod bolts, I would have to measure and see if there is a stock replacement. I used different arms+bolts.
So these ARP studs are safe to replace the factory TTY bolts? How many engines have you used them in?
I have found the factory side bolts and rod bolts, so im only looking to replace the main cap bolts at this point.
Did you torque those studs to the ARP specs or the original mopar specs?
I came across your post. I have the exact same issue you had with the main cap bolts not being available. Did you end up using the ARP 151-5406 studs? How did they fit? I'm not at a place to replace the entire engine at this point so just looking for feedback from anyone that has used these ARP bolts.
Thanks in advance for your input.
I ended up reusing the stock bolts. I read that if the bolts aren't showing signs of stretching, it is possible to re use them. I did find a few new ones online (ebay) then I simply compared measurements between new and old and they were the exact same. Ive talked with a few mechanics that are friends of mine along with the machine shop that did my machine work and they agree.
