ugg before i bring my jeep into the stealership...
Old 05-02-2012, 07:11 PM
slappygoeshome's Avatar
Default ugg before i bring my jeep into the stealership...
i figured i would post my issue here....i have a 2012 jku and today i noticed the left pass. door wouldnt close....i didnt have this issue yesterday and today i do....i didnt leave the house.....i have never remvoed the pass. doors. I have to really slam the door to get it to latch if i dont slam it it wont close and when i go to open it i really have to push the door handle it and its even then you can tell the door is just not right....i cant tell if its not lined up because it was 9:00 when i noticed the open door warning on the dash any ideas?
Old 05-02-2012, 07:13 PM
rdubb1031's Avatar
Soft or hardtop?
Old 05-02-2012, 07:15 PM
Originally Posted by rdubb1031
Soft or hardtop?
soft top for the summer i did remove the widows and put them back on tonight...
Old 05-02-2012, 07:21 PM
BLEV's Avatar
Since its a 2012, id says it's not your problem but the warranty department's!
Old 05-02-2012, 08:17 PM
rdubb1031's Avatar
I had an issue similar where the softtop wasn't on right and it was interfering with my rear pass door. Double check the soft top. If not let the warranty fix it.
Old 05-03-2012, 04:35 AM
wired's Avatar
If the door closed properly before you removed the windows, then you did not put them back on correctly. If you are new to the soft top, it takes a few times to get comfortable with it.
Good luck.
Old 05-03-2012, 05:56 AM
gregaf3's Avatar
If it is the back door, make sure that the window is all the way into the surround. If it is the front door I don't really see a way that the soft top could interfere with the door. Esp if you did not take the surrounds off.
Quick Reply: ugg before i bring my jeep into the stealership...
