Upgrade to 430N nav on 2011?
Old Sep 25, 2012 | 11:27 PM
Fiveofun's Avatar
Default Upgrade to 430N nav on 2011?
Has anyone upgraded their base 130N radio to a 430N nav radio? Is it just plug and play plus whatever is needed for the GPS antenna?
Old Sep 26, 2012 | 03:02 AM
Shell's Avatar
I wouldn't put a factory unit in I'd go with a nice aftermarket.
Old Sep 26, 2012 | 03:36 AM
AHunter's Avatar
GPS antenna and mic for using hands free phone.
Old Sep 26, 2012 | 04:45 AM
Chadc880's Avatar
The RHB 430N 2011-2013 JK's
Do you have Sirius ?
If yes then that is your GPS antenna.
If not you'll need a GPS antenna kit.
If you don't have the connectivity package In order to make the u connect work you will have to have a u connect module kit which will include the microphone and u connect module.
The 730N RHR 2011-2013 JK's
This unit already has the u connect module built-in were all you need is a microphone And satellite antenna.
Old Sep 26, 2012 | 06:29 AM
Fiveofun's Avatar
I have Sirius, UConnect, and connectivity already, so it sounds like all I would need is the head unit
Old Sep 26, 2012 | 06:31 AM
Chadc880's Avatar
Plug and play. That's all you need.
Was in the same boat and bought a 430N and have never looked back
Old Sep 26, 2012 | 06:07 PM
Fiveofun's Avatar
So does anyone know if the 430N in the JK is a high speed or low? speed radio? I ask because I found one on ebay, but it says its high speed and fits a WK.
Old Sep 26, 2012 | 06:58 PM
Chadc880's Avatar
JKs are high speed. But I thought grand Cherokees were low speed ??
Old Sep 27, 2012 | 04:54 AM
jwilson2598's Avatar
JKs are high speed, as are the new WKGrands. However, the WK and Durango use a different mounting pattern and won't work. You need the one from a JK, Ram pickup, or minivan.
Old Oct 14, 2012 | 01:10 PM
Imoutdoorsy's Avatar
I am also wanting to upgrade RES with NO conn group to 430N RHB but need to know what u-connect part number I need. Is all that matters is that it is for HS BUS?? anyone else that has done this and can provide info thank you.
