water leaking in the top of my rear door
I have a decent amount of water leaking in the top of my rear door at the b piller dose anyone know of a fix for this its 2010
You might have the "mucket" folded over wrong if you've recently ha the door surrounds or hard top off and put them back on. It's amazingly easy to get it folded wrong, especially with the door surrounds, and IMHO nearly impossible not to get it wrong and then have to rework it after the door surround is back on.
Otherwise you might check the front edge door seal on the back door, compare one side to the other. Could be a door hinge alignment is in order.
Now, I need to go fix the leaks on my A pillar on both sides ... :(
