Weird auto dash symbol?
Old May 14, 2012 | 09:01 PM
yelnref's Avatar
Originally Posted by shag7265
Yes, that would be my guess. When it shows the 1 in question hit the stick to the right and see if it turns into a 2. If so then then that is for sure what is happening .
It's kinda nice to be able to upshift or downshift a tranny when you want to.
Key words being "when you want to"!
Not so nice to suddenly find you're in 1.
Old May 16, 2012 | 06:10 PM
Bodar's Avatar
If you wanted to switch gears, why did you get an auto?
Name:	double facepalm-1.jpeg
Old May 17, 2012 | 02:18 PM
yelnref's Avatar
Who said I wanted to?
But thanks for trying to be helpful.
Old May 17, 2012 | 04:11 PM
Lefty Diego's Avatar
If you are resting your hand on the shifter, you are inadvertently shifting gears. I have done it several times. The numbers to the right of the "D" indicate what gear you are in. This is true for automatic transmissions. You really should familiarize yourself with the operation of your Jeep.
Old May 17, 2012 | 04:45 PM
CherryRed11's Avatar
Do you have overdrive on? Sounds like it might be the issue. It will keep your rpms high.
Old May 17, 2012 | 04:47 PM
ronjenx's Avatar
O/D on keeps the rpm high?
Old May 17, 2012 | 07:36 PM
yelnref's Avatar
Wasn't true for my last jeep - but I guess technology has improved since I bought that. And I looked in the manual but there's no mention that I could find of the autostick feature and dash symbols.
But it's good to know that you know everything about Jeeps. I'll know who to go to in future...
Old May 17, 2012 | 07:40 PM
yelnref's Avatar
No overdrive. Just inadvertent shifting. Though from reading around it seems some Jeeps have extra sensitive shifters.
Old May 17, 2012 | 07:55 PM
ronjenx's Avatar
I'm a little baffled why he said overdrive on will keep your rpm high.
When you say "no overdrive", is that beacause you turn it off when you start the Jeep?
Old May 17, 2012 | 08:27 PM
yelnref's Avatar
By "no overdrive" I meant the car wasn't in O/D when this happened.
I imagine the "keep your rpms high" thinking might have meant if I were in O/D and then suddenly shifted manually?
