wet floor mats passenger side
I've searched around the site for somebody who may be having the same problem but couldnt find anything. I've been having water build build up under the floor mats on the passenger side of my 2012 JKU. It's really annoying. I've looked around else where and heard it may be a A/C condenser clogged or something?
On the right side kick panel under dash there is a grommet, I have found that water runs in around it and soaks the carpet. I pulled mine out and put black urethane around the rubber and re-installed it, 2 months of monsoons and still a dry floor board!!!!!😛 It is a oblong Grommet easy to get too. Might not be your problem but was definitely mine, the water running out 0f the cowl runs down right against the grommet. Worth a shot!! Let me know if u try it and it works!!
i found that crud in the front top of the passenger door rubber gasket caused rainwater to drip in down the door and on the mat. cleaned out the dirt with a wet rag, prob solved.
I took my 2011 back to Jeep 3 times for this issue. They had to adjust the door and install a new seal on the door. Go ahead and take the carpet out until they did the leak. Then leave it out because it's better that way
Mine is at the dealer for a similar issue....they have the "leak doctors" lookong at it. I can't wait to get it back!
I had a similar issue occur with my '08 JKU. My floor/carpet would get wet under the mat after rain. I thought it may be a missing drain plug or grommet. I looked on the forum here and it turns out there was a bulletin with the dealerships in regards to the door weatherstriping. The dealership replaced the weatherstriping and have had no issues since then. I don't know if this applies to later models but I know it was a known issue.
