What axles come with your JK???
Old Jul 16, 2007 | 12:40 PM
mustangpro's Avatar
My 2 dr X was built 6/8/07, it has Dana 30 upfront and Dana 44 outback.
Old Jul 16, 2007 | 01:01 PM
00pumpkin's Avatar
Originally Posted by 07rube
i don't see a Ford 9" there. Is that the same as a 8.8"?
A ford 9 inch doesnt have a diff cover, has a center section that unbolts out of the housing. No its not the same as an 8.8"
Old Jul 16, 2007 | 02:31 PM
Renegade's Avatar
Ford 9" doesn't have a gasket. The entire 3rd member (differential carrier housing) is removable and is sealed back with silicone.
Originally Posted by Ruskin
Do you happen to know if there are any differences between a rear "X" D44 and a rear Rubicon D44? From what I've read so far, I think (totally guessing) that the alex housing is the same, but the spline count is different. Anybody know for sure?
Spline count on standard 44 rear is 30, with a revised pinion bearing and shaft. Rubicon 44 rear is 32 spline with the 4 pinion electric locker and revised pinion bearing. Both rear housings are the same.
Old Jul 16, 2007 | 02:51 PM
muddpuppy01's Avatar
hmmm thinking mine might come with hi pinion d44 front with d60 w/ tracloc for the rear atleast they are sitting in the garage
Old Jul 16, 2007 | 05:46 PM
4JEXEP4's Avatar
Originally Posted by LakeTravisJK
My 2-dr X came with D35 rear...:sad: It was a Sept build.
Because you didn't get the tow package. X and Sahara only get the 44 in the rear if you get the tow package or manual trans.
Old Jul 17, 2007 | 10:52 AM
00pumpkin's Avatar
Why arnt they sitting under your JK?
Old Jul 17, 2007 | 11:13 AM
mwilkie's Avatar
Default Not true on the "tow package or manual" only
I have a 07 Sahara with AUTO, NO tow package and the 44 rear end. It was ordered that way by the dealership. It is also listed on the window sticker as an upgrade. For those of you not sure if you have the 44 or the 35, I would check on the sticker first.
Marc
2dr Black Sahara
Old Jul 17, 2007 | 12:20 PM
mustangpro's Avatar
Marc
2dr Black Sahara
It's not on my sticker, but it is under there. Mine is a 6 speed w/o towing.
Old Jul 17, 2007 | 12:35 PM
n2jpn's Avatar
You could always get one of these handy references too:
http://www.allthingsjeep.com/atj11127.html
Old Jul 18, 2007 | 10:03 AM
Dogmeat's Avatar
i have an auto sahara, and no tow package, but i have a d44
