What is this bolt for on my steering knuckle?
Steer Stop bolt?
Used to adjust the turn radius. Sometimes people will adjust this when they go to bigger tires without going to lower backspaced rims. Remove the bolt, add a small washer, then reinstall - and the turn radius is narrowed.
That's the last structural piece of the knuckle, without it the knuckle has no stability and will cause all kinds of issues (#1 cause of death wobble), be very careful to not lose it.
Or.....it could be a steering stop too.
you probably want to keep that bolt on and adjusted to your limits of the steering box. any force on the tires will be limited to that bolt and knuckle, if not it will damage your steering box. 50cent bolt or a 500 steering box...pretty easy call IMO
