What are the hanging straps in the front wheel wells for?
I was poking around in the front wheel wells and there are obvious hanging straps in each one. Small lengths that are bolted to the steel panel behind the turn signals.
Like this, but black (not green) ...
They just hang there.
I assume that they are stock, but I am not sure as I dont know much about the JK Sahara model.
I'm only guessing, but like I said, they may be to keep the sway bar and/or its links "up and locked" and out of harms way when wheeling with the sway bar disconnected. A previous owner may have installed the straps for this purpose.
edit after seeing your picture post:
Do your sway bar links look like that, too?
I concur. Although this is the first time I've heard of a strap system included in a sway bar disconnect kit. It's cool that they are including a solution like this now.
Is that it?
I know NOTHING about all this stuff.
I take it that disconnecting the swaybar allows the wheels more movement range witch allows better wheel/tire contact with whatever they are crawling over?
