What Oil and Oil filters do you use??????
Old 04-29-2010 | 01:50 PM
thom1879's Avatar
I go with royal purple 5w20 with a fram filter, but pep boys had the royal purple filter for the same price when you buy 5 qts last time so I went with that.
rwamf's Avatar
There is a difference in filters, I work in Hydraulics and there is a difference in filters.
I use the Amsoil filters as they filter more small particles than most,
AMSOIL Ea Oil Filters (EaO) have the best efficiency rating in the automotive/light-truck market. EaO Filters provide a filtering efficiency in accordance with industry standard ISO 4548-12 of 98.7 percent at 15 microns, while competitive filters containing conventional cellulose media range from 40 to 80 percent efficiency.
Old 04-29-2010 | 01:59 PM
fadeout's Avatar
Mobil 1/ Fram...
Old 04-29-2010 | 04:36 PM
KCTW's Avatar
5W-30 Amsoil with 51348 wix filter.
Old 04-29-2010 | 05:24 PM
Jiblet's Avatar
Originally Posted by Adam3612
I wasnt having much luck with Mobil 1 5w20 synthetic oil, 4000 - 4500 kilometres and the change oil light would come on and yes the oil needed to be changed, didnt have this problem with the dino juice the dealership used. ....
the oil change indicator has no idea what kind of oil you put in the engine. It does not measure or sample the actual oil. The indicator is based on an algorithm that takes into account a variety of factors including number of cold starts, run time, run time at operating temperature, etc, etc.
Mobil, Amsoil, or Wesson oil, the OCI doesn't know/doesn't care.
Old 04-29-2010 | 06:10 PM
sloppyjoe's Avatar
I was using Mobil1 5w20 (which never let me down) but just this last change I switched to Royal Purple, in both the diffs and the engine. I also opted for the 5w30 as well. I used several different filters with knock on many (Mobil, K&N, Mopar, Fram, Napa) all had knock on cold cranks, some alot worse than others but all knocked. So I ended up using the Purolator PureOne (#PL20195) and have been super satisfied, I have had no knock period. Not once (so far) so I am definitely going to recomend it to everyone. I think I have found the combo for my JK's extended life. Royal Purple with Purolator PureOne for the win. JOE>
Old 04-30-2010 | 02:43 AM
John_B's Avatar
I use Mobil1 with Fram xtended guard filter.
Old 04-30-2010 | 05:20 AM
wolfpuppies3's Avatar
Default +1 to John B
Fram and Mobil one.
Old 04-30-2010 | 07:23 AM
Biggy's Avatar
Using Amsoil 5-20 with the Amsoil filter.
Old 04-30-2010 | 01:15 PM
BrunosJK's Avatar
X2 here the only way for me
Quick Reply: What Oil and Oil filters do you use??????
