What Pressure on 245/70/R17?
What pressure should I inflate my tires at, for on road everyday commuting?
I have Cooper STT's and as mentioned in the header dimensions are 245/70/R17.
PS What is the factory recommendation for rubicon installed 255/75/R17 MT's?
BTW for the time being I run at 35psi, however worry that it is too high, therefore the question towards the forum.
Put a thick line of chalk across the tread, drive the Jeep for a few revolutions, then look at the chalk. If it wears evenly, your pressure is good, if it wears more in the center, then you're over-inflated and thats how your tread will wear, if it wears more on the edges then you're under-inflated.
You can also do a similar test by driving the tire through some water and then looking at the tread pattern it leaves, again looking for the same indicators. The chalk test is more reliable.
