What are the small hoses that run along side with the brake lines in the front?
Old Jul 31, 2018 | 07:28 PM
CrackerJoe21's Avatar
Default What are the small hoses that run along side with the brake lines in the front?
Hello,
What is the function of the thin black plastic lines that run along side with the brake lines in the front behind the wheels?
Do they work with the ASB or vacuum booster or something?
Thanks
Old Jul 31, 2018 | 07:48 PM
resharp001's Avatar
Loved
Community Favorite
I think you're describing the ABS lines. You should see them running to the speed sensors at the hubs up front.
Old Jul 31, 2018 | 08:17 PM
Yes, they follow the brake lines from somewhere in the engine compartment down to the caliper where the brake line connects, then the line in question goes past the caliper to the front and plugs in somewhere.
What is in the line, is it just air for vaccum?
What would happen if one of these line brakes?
Old Jul 31, 2018 | 08:33 PM
OK, I think I got this (LOL) basically its a wiring harness
Old Aug 1, 2018 | 03:41 AM
resharp001's Avatar
Loved
Community Favorite
Yes, simple 2-wire, if I recall. If you brake that you'll throw an ABS code as the system loses contact with the speed sensor.
