What supports the hood?
I'd say yes for a few reasons. It channels air over the hood rather that under it. Air under the hood could cause a few issues like hood lift at speed and reduced radiator air flow from too much pressure in the engine compartment. Another reason to have one would be less road grime, water and salt in the engine compartment.
I ended up ordering the strip. The description says that it is self-adhesive (peel-off backing). Can anyone offer any tips on putting this thing on correctly? I want to make sure that it is perfectly straight, centered, and located in the proper place on the grill.
Clean the area, then clean the area again, then use mineral spirits or alcohol to clean it last time for dust, then install happily.
In other words, don't start by pulling off all the backing.
