Wheel Hop
Wheel Hop
I just picked up a 2015 JKUR. When I have both lockers locked I get wheel hop really bad mostly in soft sand. If I'm aired down it goes away. Do lift kits help with the wheel hop?
No, they generally make it worse. Not sure why you are using lockers in sand but airing down in sand is really a must and as low as you can go. I would aim for the 8-10 psi range.
Lockers in sand are a good way to dig to China. What's your location? On the East Coast the softest sand we've got only requires 12psi but usually you can get away with 15-18psi without any change in performance. If you're elsewhere then Dirtman's response may be a better guideline.
