Wheel Locks!
Old Feb 10, 2010 | 06:56 PM
tw!sted's Avatar
Exclamation Wheel Locks!
I just bought my JK and I am getting ready to install a TF coil lift.. I guess the company who did the last tire rotation, WAY over torqued the wheel locks. I spent about 2 hours with a hammer, 4' bar and a torch trying to these retarded things off.
I was able to get one off, the others just strip out.
Anyone have any suggestion on how to get them off? I tried hammering a socket over the lock with no luck.
Any help would be great.
Old Feb 10, 2010 | 06:59 PM
Ericker's Avatar
Take it back to the place that did your tires last time and make them take them off. Just my 2 cents.
Old Feb 10, 2010 | 07:04 PM
tw!sted's Avatar
Yeah. I just bought the Jeep I don't know who did the rotation. Trust me I would have definitely taken it back. heh
Old Feb 10, 2010 | 07:07 PM
captjay's Avatar
yea what he said.
are u using the key or no key for the wheel loc
edit: sorry just read u didnt know who
Old Feb 10, 2010 | 07:14 PM
captjay's Avatar
if u do not have the key, take it to diferent tire shops, they carry various brand and size wheel lock keys. just keep checking the shops. thats how i got mine off, but went through 5 shops before found one that had the correct key
Old Feb 10, 2010 | 08:52 PM
tw!sted's Avatar
Hi - I have the key, but the locks are so stripped its useless. The key actually warped from the amount of pressure trying to loosen it.
I will see if I can find a tire shop to do this.
Thanks for the replies.
Old Feb 10, 2010 | 09:04 PM
captjay's Avatar
depending on the rim, could u get a pipe wrench on the lock to get a better bite then use the cheater bar (your 4' bar) or u may have to get an impact gun on it
if u can get a better bite wth the pipe wrech and use the bar, there is no reason they should not come off with that much leverage
edit: be carefull as u might end up breaking the stud off before the wheel lock comes off
Old Feb 10, 2010 | 09:59 PM
Riptide's Avatar
When I lost my nut keys for my 300z I just had nissan cut them off. Cost $15.
Old Feb 10, 2010 | 10:06 PM
sclan's Avatar
I hate it when tire shops use impact wrenchs to put the lugs back on.
Rule: Impact wrench to take off only.
I've stopped a tire shop from using an impact wrench when I saw them through the glass using it as a machine gun. BTW, they torqued TWO of the nuts so much that they busted 2 of my lugs. Oh, and the lugs have to be purchased/ordered through the dealer using your VIN.
Old Feb 10, 2010 | 10:52 PM
tw!sted's Avatar
Yeah its frustrating! This guy must have sat on the impact for 20 minutes, I broke the lug nuts lose, but wheel locks won't move.. On a serious note, you would be screwed if you pulled a bead on a technical remote trail and couldn't get the damn tire off.
I was only able to get one lose, hopefully a tire shop can help me out here..
I have seen some "wheel lock" removal tools online, so if a tire shop cant help I guess I will give that a try.
