Where is the Evaporator Core Located? Don't Need to Remove it. Read on.....
I bought a Klima Cleaner which has worked great on my past cars. It's one of those fresheners that you spray into the evaporator via a long tube and I need to know where to apply it. I also need to make sure I spray it into the side where the air enters the evaporator so the chemical goes through it. Any feedback appreicated.
Thanks!
Thanks!
I am not familiar with the product you are wishing to use. The air intake for the air conditioner / heater is the cowl between the hood and windshield. You should be able to turn the defroster on, air conditioner on, fan on high and spray into the cowl. The blower should pull the spray from the cowl and force it through the evaporator core. If your Jeep has a cabin air filter (check your owner manual) you could remove the filter and spray in the duct there.
Good luck.
Good luck.
Is this a product used by AC professionals to clean the evaporator coils? Chad probably has the best idea although I would be cautious, some of that stuff is pretty harsh and can eat gaskets and seals.
Good luck.
Good luck.
No more stale odor from my vents
Thanks guys!
