Wiring and switch for fog lights on stock x
Old Aug 20, 2008 | 08:38 PM
cgtweet's Avatar
Default Wiring and switch for fog lights on stock x
Does anyone know if the stock x without fogs has the wiring installed? And is the light switch configured for the fog lights on/off or does that need to be replaced?
Old Aug 20, 2008 | 11:22 PM
TINMAN080's Avatar
turn your light stalk on, then pull the end of the stalk out like you are lenghening it. If it doesn't snap out 1/4'' and stay then you don't have the correct switch. Under the front bumper you should have double 2 wire pigtails not plugged in to anything if you are wired, if not you will have to wire them. Check with your parts dept., there may be a fog lamp accessory kit for this that has everything you will need....
Old Aug 21, 2008 | 05:11 AM
cgtweet's Avatar
Default re
Thanks. I am selling my stock bumper with fogs and hooks and wanted to make sure the person buying it can use it.
Old Aug 21, 2008 | 05:15 AM
xblazerman's Avatar
I have an X and when I bought the driving lights through jeep I also had to buy the wiring kit.It came with the turn signal stalk.I think the wiring kit was around $100.
