wobble at 55-65 only
I have a 07 Sahara Unlimited and I am getting a wobble, mainly noticeable through the steering wheel, only around 55mph to 65 mph almost on the dot between those speeds. What's the first thing to check to fix this? I know it could be a number of issues, just hoping someone could help narrow it down a little for me. Oh and this vehicle is bone stock as of now.
If the 'wobble' is speed specific, 1st have the tires balanced. 90% of the time that will cure the issue. They will also be able to tell you if your tire is too far outside limits to balance. Downside to that is you will need to purchase another tire to replace it or use your spare.
Good idea to try the tires first--check pressures and rotate, see if problem changes. I wouldn't pay anyone the typical going rate to balance the tires, however, before checking a few other free things that can cause this (and most especially if your '07 has typical mileage for that year):
If after making those free checks you still have the problem, then consider paying someone to balance the tires. When mine started doing exactly as you describe, it turned out to be the ball joints.
- Uneven tire wear (if so, check the shocks)
- Gunk on a wheel (mud from off-roading?)
- Tie rod ends
- Drag link ends
- Ball joints
Check your tires for out of balance/out of round....IMMEDIATELY. Then check out the thread from Planman on diagnosing death wobble and follow ALL the steps thoroughly.
I had that same vibration but didn't worry about it, after a wheeling trip it exploded into full on death wobble any time I got over 35mph...and I had to drive 100+miles to get home.
check your brake rotors also.
I had the wobble/vibration in my 2008 JK for couple years...
I had my brakes (pad and rotors) replaced and that wobble/vibration went away and my jeep rides really smooth now especially with the new MT ATZ P3's on her... after having my old MT 33's rotated and balanced at least 4 times to try to get the annoying wobble out of there.
If you ever had to get hard on your brakes to slow and/or had them overheat (going down thru mountains etc.)... that is enough to cause a slight rotor warp. I had mine overheat going thru the Smokey Mountains heading to Gatlinburg, TN. and that wobble started after that trip. Replaced brake pads and not the rotors cause the rotors looked fine (no grooves) and smooth during that span and still had the vibration and slight wobble until I replaced all.
Hope this helps.
Hope this helps.
Thanks everyone. Well I diagnosed that I'm either blind or an idiot, lol. After much crawling around under my jeep, boom there it was. Driver side front tire was somehow missing it's wheel weight. Not sure if it fell off or what, but swapped my spare out (which I rotate regularly with the other tires) and wobble is GONE! Booyah. The brake issues has me intrigued though. I've notice a little brake squeal lately, so I will change pads ASAP! Thanks again for the advice and info everyone!
Amazon.com: CRC Disc Brake Quiet 05016, 4 Fl Oz: Automotive
