Wrong Way Turn Signal
I've searched the forums and have not seen anyone report this weird problem I'm having.
Sometimes when I turn on the right turn signal, the left one will come on momentarily, then the right one comes on and blinks normally. I first noticed it while using the "momentary three-blink" feature. I lift the control to activate the right signal and the left one blinks three times!! The first time I noticed it, I didn't believe what I was seeing. Now that I'm watching it, I see it happen quite often. I've had to stop using the three-blink feature because of this. Has anyone else experienced this? Of course it happened after the warranty expired.
Any input will be greatly appreciated!
If it was a PC I'd re-boot it to see if that helped, but I don't know how to do that to a JK.
Thanks for the idea, but it happens before I even let go of the lever. Even when I lift it all the way to lock the right signal on, it will occasionally light the left light for a split second and then start blinking the right signal.
That's the closest thing to a re-boot you can do, and it actually works for a lot of strange behaviors.
