Trouble removing door wire harness
Need some help!
I wanted to take the doors off of my 2012 Jk, but I cannot get the damn wiring harness unhooked on either door.
Has anyone else had this issue? I feel like Im going to break it because I'm pulling so hard, even after I flip the little switch on the harness.
Need some help!
My hands are usually bleeding after I unhook all 4 doors on my jeep.
Make sure the little red slide thingy is disengaged. Once this is done you should be able to press the button on the bottom and slide it off, if the red thing is in the wrong position you won't be able to press the black button on bottom.
What he said was really right. You must follow this instruction to unhook the door of your Jeep.
