Official VA Thread
Old Dec 10, 2011 | 10:46 PM
  #1001
SayreJK07's Avatar
Go 35's with the BB. I have 2.5 inch with 35's.
Old Dec 10, 2011 | 11:07 PM
  #1002
SayreJK07's Avatar
Going to pick up my freedom top from Jagermeister427 today. Pretty pumped. Hope it is in pretty good condition. I would hate to drive 9 hours round trip for nothing.
Old Dec 11, 2011 | 05:46 AM
  #1003
duglas's Avatar
Originally Posted by Battlefrog
You should be fine with that and the Hemi will def help as well. It's not horrible as long as you know beforehand that "low/high blues" don't really exist.. It's pretty much low to high blacks.. I'd love to run it again, I'm just not set up for like I'd want to be.. I'm running a D30 and it really needs to be sleeved and gusseted for that run.. I've seen your setup when we went to the beach and you will be fine.. The lockers and 37's are going to make a huge diff..... Take some pics!
Well went to Crozet yesterday, had a good time most of the day, only did low and mid blues most of the day. Then around 3 I went on a low black stream bed trail, boy was that a mistake. Destroyed both Side rails/steps and rock rashed both rear rims all the way around.. I also had to use my rear bumper to push/slide a huge rock out of my way. I also actually got my steering arm stuck inside a tree trunk and had to high lift off it and messed my alignment off bad. It was dark when I left and cold so I went to Merchants and got an alignment instead of doing another "trail alignment".
Was fun but I will not go back with a JKU.. You need a 2 door for most of it.
Old Dec 11, 2011 | 05:50 AM
  #1004
Battlefrog's Avatar
I believe I know what stream bed your referring to. Did it have some HUGE rocks on the right side as you were entering, and a decent ledge to climb before crawling through the stream bed? If so, yes, it is a rough obstacle. I did that and changed my mind about continuing shortly after... That sucks that you sustained all that damage..
Old Dec 11, 2011 | 01:32 PM
  #1005
ty01's Avatar
hey whats going on guys? anybody planning a trip soon?
Old Dec 11, 2011 | 01:34 PM
  #1006
Battlefrog's Avatar
Haha, what's up TY.. I'm gonna try to hit up Uwharrie with Karl's brother adam (hopefully Karl as well) on 6-7 jan.. Maybe camp for that weekend..
Old Dec 11, 2011 | 01:48 PM
  #1007
ty01's Avatar
sounds bad ass!!! let do it
Old Dec 11, 2011 | 01:55 PM
  #1008
SayreJK07's Avatar
Should be in... I'll check my calendar
Old Dec 11, 2011 | 02:45 PM
  #1009
Battlefrog's Avatar
Cool, I will be solo cause the wife leaves for school on the 6th as well...
Old Dec 11, 2011 | 04:09 PM
  #1010
salerno's Avatar
Is Uwharrie something I can do stock or able to bypass obstacles too much for stock? Not sure i will have the lift and tires installed by 6th. Maybe... maybe not.
