Bolts at front seat ceased up
Old Apr 13, 2013 | 02:33 PM
Dorlando1's Avatar
Default Bolts at front seat ceased up
I bought one of the under seat Bestop security boxes for my 2008 Jeep JK and I cannot get the bolts loose, my concern is if I break the bolts there is no access to the nuts in the underside. Does anyone have any ideas on how to get these bolts loose without snapping them. If I do snap them, how do I get access to the nuts on the underside?
Old Apr 13, 2013 | 02:41 PM
Mark73's Avatar
They have lock tight on them and r a bugger to get out . I was scared mine would snap when I did my bed liner under my seat . I used a breaker bar and crossed my fingers . Good luck
Old Apr 13, 2013 | 02:53 PM
tribulation138's Avatar
Mapp gas torch
Old Apr 13, 2013 | 03:25 PM
ToolManTimTaylor's Avatar
Wire brush the exposed portions from under the Jeep. After brushing lube em up! They put up very little fight after that. OOps Just reread .... FRONT bolts ... Sorry
Old Apr 13, 2013 | 04:44 PM
road_king's Avatar
Yes they are really hard to get off - you're not going to break them - a long breaker bar is in order.
Sent from my iPad using Tapatalk HD
Old Apr 14, 2013 | 04:00 PM
Dorlando1's Avatar
I figured the breaker bar was the option but wanted to check.
Old Apr 14, 2013 | 06:17 PM
steveo_01vwgolf's Avatar
Default breaker bar...
Had the same issue 2 weeks ago using a regular socket set... breaker bar and I was done in 5 minutes.
Old Apr 16, 2013 | 09:16 AM
LACAPITAN's Avatar
haha I ran into the same problem yesterday with my install. I was thinking about going to a mechanic and just paying a few bucks to have them loosen it with one of their air guns. Wasn't sure of my options but thanks guys for the breaker bar tip! I'll borrow one and try that first.
Old Apr 18, 2013 | 09:13 PM
LACAPITAN's Avatar
So I used a 15" Breaker Bar...and as the others mentioned in previous posts, no struggle to get the bolts off. Just thought I'd add a picture for anyone looking for a quick reference:
Old Apr 21, 2013 | 11:23 AM
Dorlando1's Avatar
I used a pipe in the end off the ratchet and it worked perfect
