Antenna
Old Aug 9, 2012 | 08:39 PM
Jeek.OlllllllO's Avatar
Originally Posted by Rooster76
ANTENNA THEORY
The antenna makes all the difference in CB's, that are limited to 4 Watts. You want to make sure you get the mount grounded well. Then you need to tune them with a SWR meter. In theory you want antennas to be as high as possible and have 1/3 above the roof. The longer the antenna the better the range you will get. It's best not to sanwitch you antenna in between the tire and window like I have mine mounted. A better option is the Arizona Rocky Road mount that extends the mount over the spare tire.
A whip is the best in theory. I was thinking they were 102" (8.5'). If I remember right that is a 1/4" of a CB wavelength. I say best in theory because the thing is 8.5' tall (or damb close at least ) and it whips all over the place and is not very trail friendly to anyone around the Jeep and are not allowed in some places and clubs. Also it requires a beefy mount to hold it up. I do think they look cool as hell though.
Firestik FireFly Antenna
As for the best Antenna for actual off-road use I would say the Firestik FireFly Antenna. It will have FL in the name if it is a firefly. Don't confused the firefly with firestiks other models that are much more ridged and require a spring . It's very flexible (and doesn't need a spring), Light weight, More top wound than than the more common Firestick II. It also gives you about a mile better range then the super flexible Wilson Flex. The firefly comes in 3' and 4' lengths. According to "Right Channel Radio's" you can expect the range to be
3' Length: 3 to 4 miles
4' Length: 4 to 6 miles
I've got the 3' mounted to the base of the spare. It is an 1" longer then my garage clearance and it creates no problem for the antenna or door frame. It has a tune-able tip screw for adjusting the SWR that is covered with a plastic cap. It's a good idea to put some hairspray in the cap after you have adjusted the antenna. That's the same way you keep on mountain bike grips.
Here is a firefly that comes standard with a cooltech ultramount shown below
If you decided to get something else at the local truck stop I would make sure it has a tune-able tip. These dudes are only about $20 and there is no reason to have to fiddle with trimming wire to adjust the SWR.
Good Luck
Wait you have to ground you mount?
Old Aug 9, 2012 | 09:03 PM
Rooster76's Avatar
Yeah, the way it works is that when your receiving your actually using the Jeeps steel body as part of the antenna. There are parts that are hot and there are parts that need to be grounded for the antenna to work. It's very important how you put on your antenna stud for all this to work out right. Most notably the white washer. You can test this with a multi-meter ($14) on the Ohm setting.
It's quite possible that when you mount your antenna it will be grounded well enough to work. To get the best performance and lower your SWR you need to have it grounded to the tub. The nylon bushings that hold the rear gate on can prevent this. The easiest solution is to run a 10 or 12 guage wire from a bolt on the mount, to a bolt in the tub. It has to have the paint removed under the bolts to work.
I did a writeup about it here that goes more into it. LINK->https://www.jk-forum.com/forums/jk-w...2012-a-231369/
Old Aug 9, 2012 | 09:10 PM
Yeah, the way it works is that when your receiving your actually using the body frame as part of the antenna. There are parts that are hot and there are parts that need to be grounded for the antenna to work. It's very important how you put on your antenna stud for all this to work out right. Most notably the white washer. You can test this with a multi-meter ($14) on the Ohm setting.
It's quite possible that when you mount your antenna it will be grounded well enough to work, but to get the best performance and lower your SWR you need to have it grounded to the tub. The nylon bushings that hold the rear gate on can prevent this.
Look at my previous picture i made my own mount that is attached to the tail gate so idk im confused :/
And to ground it what do i need?
Old Aug 9, 2012 | 10:08 PM
What wire should i use?
Old Aug 10, 2012 | 07:52 AM
Smitty12JKU's Avatar
Link>Here is another mount idea that also shows grounding. I have a 3', 4' and 5' Wilson that all work on the mount. The shorter antennas can work just fine for the trail chatter. Well tuned and grounded should get out a few miles or better. I had a cobra 29 with a whip that could talk 13 miles or better depending on conditions. On fiberglass rear of the Jeep antennas I can get 5-6 approx. This acceptable for me beccause the whip hits everything and I have a garage that I park the Jeep in.
I also agree with the Firestik Firefly but also like the Wilson Flex.
Old Aug 10, 2012 | 08:11 AM
I turned on my cb to see if it was working and i was hearing people talk for like 30 seconds then i turned it off
Old Aug 10, 2012 | 05:40 PM
CW Spook's Avatar
Your ears and your sanity are better for that.
Old Aug 10, 2012 | 05:53 PM
Well today i grounded the mount and turned on the cb and was able to here some trucker's about 3 miles away
Old Aug 10, 2012 | 07:20 PM
CW Spook's Avatar
Oh..I thought that was probably why you shut it off the first time... That usually does it for me.
Old Aug 10, 2012 | 07:29 PM
It did it for me so ima just see if i can tune it and ill be set
