antenna and mounting question
Old Dec 31, 2009 | 08:15 PM
sully151's Avatar
Default antenna and mounting question
I just got a cb for Christmas, but did not get the antenna or mount.
Which is better the Firestik Firefly or the firestik ll ?
I believe both of them will work with the weather function on my Cobra 25.
Second, I think I may do the cooltech mount and want to know which would be better the gate mount or the ultramount?
http://www.cooltechllc.com/jeep/jk_gatemount.htm
http://www.cooltechllc.com/jeep/jk_ultramount.htm
Old Dec 31, 2009 | 10:00 PM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
It all depends on which one you personally like.
Iv got the Ultra mount on mine and like it.
Hope this helps out.
Old Jan 1, 2010 | 10:39 AM
Yamaha90's Avatar
My girlfriend got my the Firestik II FS for christmas and it's got the tip on the top that your turn with your fingers to tune it so it's really easy to tune once you use somebody's SWR meter. My 3' firestik i mounted on the back on the tire carrier, the cooltec mounts were way to expensive for me, but uckily her dad is big into restoring cars and building cars so we fabbed one up in about an hour it was cut, welded, ground down, cleaned, primed and painted i'll post up some pictures after i take a few shots of it. i have to re route my cable after i get a longer cable, it's going to go through the gate and come out of the rubber gromet on the gate for a nice clean look.
Old Jan 1, 2010 | 11:10 AM
Biggy's Avatar
I have the gatemount and think its great. Its a quality product. The ultramount is nice also but if you wheel your rig there is a greater chance of it getting ripped off. Thats happened to a few guys here. I say if you wheel alot go with the gatemount and the ultra if you dont.
Old Jan 13, 2010 | 03:10 PM
BillyJack's Avatar
Just checked out the gatemount. Is that enough metal to mount grounding?
Old Jan 13, 2010 | 06:49 PM
NorthRiver's Avatar
Get the Firefly. The Firestiks are about 5/8" diameter and aren't flexible at all.
The Firefly are much smaller and much more flexible.
Old Jan 27, 2010 | 07:28 PM
Highlander's Avatar
Check out the Everhardt Tiger TSM 4'Super Flex Wave it is like $11.50 at CB World and it is a very good antenna. Check out my gallery I have a picture of my mount
Old Jan 27, 2010 | 09:26 PM
mmccurdy's Avatar
I am one of those guys, managed to bang up and dent my rear quarter pretty badly in the process.
I would say go for the gate mount. No real difference in performance, and the antenna will be tucked out of the way.
Old Jan 28, 2010 | 06:47 AM
Dex1's Avatar
I have the Firestick II, it has the "adjustable" tip, makes it real easy to tune.
I mounted it on a Teraflex mount on the tire carrier, works good...
Old Jan 28, 2010 | 09:54 AM
Bling's Avatar
K40 mounted to tailgate using bolt in OEM tire carrier and a cheapo bracket from Radio Shack. Bracket is basically a piece of metal bent 90 degrees with a hole in each end. I placed the bolt through one and the antenna through the other
