Antennae question
Old Mar 12, 2012 | 03:37 PM
jim hensley's Avatar
Default Antennae question
I need to get in a parking garage daily. Would a 3 ft antennae work mounted on the rear bumper. If so is it a significant downgrade on range. Which antennae do you all recommend?
Old Mar 12, 2012 | 03:58 PM
Dagley918's Avatar
I have a 4ft and it barely bumps the rubber seal in my garage door so a 3ft I would imagine would clear your parking garage.
As for range I could not share any knowledge.
Old Mar 12, 2012 | 04:01 PM
How far above the roof does your antennae extend?
Old Mar 13, 2012 | 06:45 PM
TAIL RATED's Avatar
do a 4ft and a quick release. makes pulling into the garge better and the 4ft will get up above that roof line a little better.
Old Mar 13, 2012 | 07:21 PM
Dagley918's Avatar
I'd say 8-10" I thought the 3' wouldn't get me a good shot of getting a signal out. I mounted it with the cooltech ultra mount of of the license plate holder.
Old Mar 14, 2012 | 08:58 AM
So you're saying pull the antennae off each day before pulling into the garage? Seems like a hassle and what if I forget. I guess I could pull it off and only put it back on when I plan on using it. Primary use will be communication on trail rides or for amusement while on the road on trips.
Old Mar 14, 2012 | 09:27 AM
jeepjkgrrl's Avatar
With 3.25" lift and 35" my 5 ft whip hits 8.8ft tall
