CB antenna tuning
Old Nov 11, 2008 | 07:50 AM
-MAW-'s Avatar
Default CB antenna tuning
What would happen if I didn't tune my antenna?
Old Nov 11, 2008 | 08:17 AM
-MAW-'s Avatar
Thumbs up
THX so one could damage the radio
Will go get a swr meter then
Old Nov 11, 2008 | 08:57 AM
Rhino64's Avatar
It's not likely you will damage it because of the low power it has. However if you don't tune it, it will not preform as well. If your going to use it for just trail rides it probably won't really matter much, most vehicles are pretty close together. Its always better to tune it if you can. don't ever key it without the antenna hooked up are you will damage it.
Old Nov 11, 2008 | 11:47 AM
-MAW-'s Avatar
Well that was a waste of 30 bucks
Hooked up the meter calibrated it and turned on the CB and tested on ch 20 and meter read 1 and ch 40 read 1.1 so didn't bother checking ch 1
How often does something come plug'n play
Guess I just got lucky
Thanks for the advise guys
Old Nov 11, 2008 | 12:23 PM
dburgette's Avatar
Take it back and see if you can get your money back. Just a thought! I need one so maybe you could sell it to me at a discount...kind of like splitting the cost.
Old Nov 11, 2008 | 12:27 PM
Trick Cyclist's Avatar
Where did you get the meter from? Need to tune mine too (but I expect mine won't be plug and play!)
Old Nov 11, 2008 | 01:28 PM
kenny Kustom's Avatar
Are you sure you are doing it right ? ? Never seen a perfect 1:1 right out of the box.
Meter inline between the radio and antenna
turn switch to foward, key mic and hold
turn knob to calibrate
turn switch to REF
view swr reading.
Old Nov 11, 2008 | 01:45 PM
artpics's Avatar
Frys has one for $9.95 Vanco
Old Nov 11, 2008 | 01:54 PM
jsmoriss's Avatar
Matt,
Not very patient, ey? I have a meter, but never needed to use it because my Cobra 29 has a meter built in. :-)
Check channels 1 and 40. Don't forget to calibrate on channel 1, then measure SWR, then tune to channel 40 and CALIBRATE AGAIN, then check SWR. If SWR is higher on channel 40, your antenna is too long, and if it's lower, your antenna is too short.
BTW, try and use the shortest coax possible between your CB and meter.
js.
Old Nov 11, 2008 | 02:09 PM
I dont trust the built in meters.
